Pete Davenport
After removing the portlights, discovered that all on the port side were wet and all on the starboard side were dry. Go figure. I'm wondering if there was a problem with a lot, different installers, or whatever?Bottom-line, I've been letting the cut-outs dry out (see picture of aft-most port cut-out. You can see the inner fiberglass shell is falling away from the plywood. Not having the same problem on the starboard side.I think I need to re-glue the fiberglass to the plywood before re-installing the portlights. I'm also planning to chisel out 1/2" or so of plywood on bottom edge of all port cut-outs and fill with marine epoxy.Anyone dealt with this problem before? Any suggestions.Murphy has taken up residence......
