O
Olivier Ruhlmann
I have recieved my ports this weekend, ans started removing the old ones.Here are a few things to watch out for:Both the haul and the cabin tops are 3/8" thick - solid fiberglass. This means two things:1) You do not need to fill any core material when you replace the ports.2) You need to buy an additional 5/8" teack liner for each port (you get a big discount for large quantities - ten in my case.)The existing cut out match the new cut out dimensions almost perfectly, so not too much work is needed to resize the cut outs.If you decide to install a round port near the galley, make sure to specify the right size spigot: The cabin wall is two inches thick and the regular spigot will not work.For those who think that 3/8" is "thin" I was happy to read the last question on the newfoundmetals web site: Bristols 34 (a boat built for going offshore)has a cabin thickness of 3/8", where only 1/4" is fiberglass and 1/8" is liner...
