Mark T
I have the original Hood 810LD furler on my 35.5. It has consistently performed poorly. Now it is completely frozen, and I'd guess that the bearings are shot. I've read all of the archives, and understand that the most common fix is to replace with the 800SL upgrade kit. That sounds like the easiest solution, but given the inferior performance of the 810LD, and reading a few forum posts about problems with the 800SL, I'd much prefer to use a better furler.The problem is the size of the deck cutout in the 35.5. I need to keep the furler below deck because I have a significant investment in two laminate genoas that would need to be recut if I put the furler above the deck.My first choice would be the Harken Mark III, but the drum appears to be 7 3/4" in diameter, when the deck cutout is about 7 1/2" in diameter.Does anyone know of any furler other than the Hood that will fir the boat?Thanks,Mark
