Hi all,
thanks for the many excellent proposals how to make a seat to sit
comfortably on the coaming. I'll be sure to try out something along
those lines. Any photos you might have would be very useful!
Meanwhile, I've come across my next "little" problem:
It appears that there is a "dripless" seal packing on the engine shaft
which has begun to leak. I assume the engine shaft is 3/4" in
diameter. The packing is at the end of a rubber hose which is clamped
to it and a kind of through-port. The leak appears to be between one
of the tightening nuts and the thread of the actual packing (looks
bluish, but could be corroded copper). I would be very grateful if
y'all can point me to any information on how to maintain the packing,
where to get a new one, and any drawings on how it looks like inside.
Any tips on how I can stop (or slow down) the leak without having to
take the boat out of the water for now would be very helpful. (Right
now the bilge pump can handle it just fine - coming on every hour or
so. But I hate to think what would happen if the bilge pump dies...)
Thanks for all your sage advice - Sebastian
