C
Charles Duhon
IS THE TRUTH OUT THERE?... about the correct prop size(PITCH?) for my 1983 H 34? I've searched the archives and only got more confused. Called Hunter Marine, they were not sure if they kept using the wrong prop after switching to the Yanmar 3GMF.Yanmar says it really depends on the reduction gear ratio, I have the Hurth transmission but not sure of the ratio.The prop I have now is a 15x12 does this number refer to diameter (15) and pitch 12)? If the prop I need is a 15x15 don't I need to change just the pitch ? A local propeller shop can change the pitch on my prop to 14 for only $35 as compared to $195 for a new 15x15 prop.Also interested in the alteration to a prop that can reduce prop walk (sure), the shop here had not heard of thisI have noticed it takes a LOT of reverse thrust to stop and the boat seems underpowered in forward. I thought it was just not enough horsepower but now I believe it is the prop. Looking for someone with specific experience on this subject... and always, thanksCharles & Lynn"Artistry"
