Is your engine putting out?
Steve:I am not sure which engine you have but the first things to check would be to make sure your engine in running properly. Which engine do you have? Make sure that you are getting max RPM's from the engine under load. Is your bottom clean? A dirty bottom can make a BIG difference in speed. If your engine is not running properly you can check the mixing elbow, injectors, fuel and filters. Just a few things to check.After these things you should have your existing prop checked to make sure you have the correct pitch and prop size for the boat/engine combination.
