I'm in the process of following Maine Sail's great advice re compounding and waxing my new-to-me '81 Hunter which has probably not been maintained in at least 20 years - may well be longer.
I wrote and got great advice a couple of weeks ago about wet sanding and buffing and have completed the wet sanding of one side. I have now started the buffing, about which I have the following questions:
My understanding is that you should expect to spend approximately 2 to 3 minutes per 2' x 2' area using the Presta Gelcoat Compound for a properly prepared surface. My question is how reflective should I expect the gelcoat to be after this step?
Also, I assume that in Maine Sail's procedure he classifies the Finesse It/Presta Ultra Cutting Creme as part of the compounding, although he calls for it to be buffed with the yellow wool polishing pad. Is this correct? Does it get applied in the same way, same 2 to 3 minutes per 2' x 2' area?
Any advice would be much appreciated.
