Joseph Massimino
The two Cam Cleats located next to the winches for the jib sheets, one on starboard, the other on port are looking pretty bad. One of them has one side that will not spring back. I would like to know what size line should be used on the jib for a C22? I can buy Cam Cleats at a local marine salvage store (new part) that have a stainless steel plate, and a guide for the line. They appear to be big enough for a 3/8 line. They would be screwed down by two screws, one straight through the center of each cam. Could I use them if they hold up to a 3/8 line, or should they be bigger? Can I install them on top of a teak block. The cam cleats that are there now have, what looks like, a fiberglass looking cam, and they appear to be mounted on a wood block. I guess I could look at other C22's in the marina where my boat is, but I value the advice I've been getting here.Thanks.. Joe
