Thanks for the advice.If the keel is kept up it prevents it back and forth movement caused by wave action. This movement eats out the keel bushing or the pin hole and wears the pin. Expensive and needless in fresh water.
Salt water has different issues. Because of critter growth, as in shell life and flora, a keel in the raised position can become so covered in growth that it won't release and must be forced down. The opposite can happen and it won't raise when needed. Bottom paint is the answer most trust.
Ray
keel down will provide more stability if the mooring field is rockin and rollinShould the keel be up or down when on a bouy? Does it matter if waves are hitting from a side cliff?
Really, really good point. If the cable snaps, the keel drops, then there is a high chance of busting stuff*. A big crack in the hull and the boat can easily take on water much faster than any bilge pump can get it out. Can you sleep at night with the keel up worrying about the cable? I couldn't.I have kept my boat on a mooring for 24 of the last 35 years and I always leave the keel down. This takes the strain off the keel cable which is, IMHO, the weak link in the system.
