Winter log...
Allen,I'm also in Boston, where do you sail from?Winter log rules can vary by location. In Dorchester Bay (Boston, MA) winter logs are permitted, but they are not in rest of the harbor. They should be marked with a blue band of reflective tape.My 350 lb. mooring has 20 ft of top chain, 20 feet of bottom chain. Water depth at low tide is about 9 feet. I use 20 feet of light "winter" chain to connect the log to the top chain.I use a 5 foot long cedar fence post that was obtained for free from the scrap pile at a local fence company. I drilled a 1 inch diameter hole in one end to loop the winter chain through. The chain and shackles can be purchased at home depot. Get some small tie wraps and a small bucket to carry and store the chain in, too. Also a large hook is helpful. I purchased one for about $3 that has a retaining latch and spring. I broke off the latch with a pliers to get it out of the way. This is used to hook on the chain and tie off temporarily so you don't have to struggle with it so much (the chain is heavy).At the top end of the log, I drilled a 1/2 inch or so hole and passed a peice of line through it and tied into a loop to form a handle. Makes the log easier to carry and also to retrieve in the spring. It makes lifting a 5 foot long, wet, slimey log with 20 feet of chain out of the water much easier.I also drilled a hole in the top lip of my mooring ball and tied a loop of line to it for a handle. Makes handling it much easier.To attach the log to your top chain, pass the light chain through the 1 inch hole and attach the end back to the chain with a shackle. Bring some small tie wraps along and secure the shacke pin with two of them. There is a hole in the shackle pin for that purpose.Secure the other end of the light chain to the top chain in the same way.Here are some pointers.1. If you have a GPS, mark and record the coordinates for your mooring location in case you do loose your log -- it happens.2. Mark your chain in a conspicuous way -- put a tie wrap or two a certain number of links from the top, for instance. Record this for reference, too.3. Wear old clothes, bring leather gardening gloves -- it is a messy job and there will probably be all kinds of sharp nasty stuff growing on your mooring ball and top chain.4. Do the work at low tide -- more of the chain is resting on the bottom and it isn't as heavy to work with.Here's how I take my mooring ball off. I have an open transome H260 so I can work from the swim platform. I cut a piece of 2 x 8 board to hang across the stern to protect from the chain and ball.My top chain passes through the mooring ball and is shackled to the pennants on top. Yours may be different.Engine warmed up and idling in nuetral, tools and gear ready in the cockpit, I untie the pennant from the bow and walk it back to the stern and tie off the pennant to a cleat.I have already attached the top of the winter chain to the log.Next I take an old dock line with one end already fastened to a cleat, and loop it through the mooring chain UNDER THE MOORING BALL (Rub a spot clean with a gloved hand) then tie it off to the same cleat. Now your boat is tied to the chain and you can remove the pennant and mooring ball and set them aside. Note, using the loop of line for a handle, I simply tie my mooring ball aside the boat using a dock line to prevent having to haul the slimey thing into the cockpit.Loop the bottom end of your winter chain through the end of the top chain and shackle it back to itself -- secure the pin with tie wraps (use two).At this point the winter chain is still mostly in the bucket, you are going to pay it out slowly as you drift away from the mooring. If you simply throw it all overboard, there is a good chance it will tangle on the top chain and it, the log and everything will get dragged to the bottom.Get ready to cast off: secure any unneeded tools, equipment, etc. Look around for obstacles and plan your exit. When ready hold the bottom end of the winter chain securely -- you're about to get the whole weight of the top chain -- and untie the dock line on the chain and let it slip free.Gently pay out the winter chain as you drift from the mooring, keep it away from the motor. When you get near the end, throw the log over and your on your way.Good luck,Tom
