Mooring preparation in the event of a hurricane
Dec 11, 2015
306
Hunter 25 Plymouth
I don't believe the area I'm located in (North East) is in any threat of experiencing a hurricane at this juncture and I give my best to those that are in Irma's path. However, in the event of a hurricane, can anyone suggest how I may beef up my moored boat mooring? I'm in a protected harbor with a jetty and I'm on a municipal mooring. To prepare, should I also throw out an anchor or two and if so, how would I configure then? Any wisdom appreciated.
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
Are you in Plymouth? It seems like a well protected harbor. I would ask the Harbormaster, and whoever maintains your mooring. I would be careful about additional anchors, since they may not all pull together, and you may swing funny and hit things.
I think one of the biggest risks in a moderate hurricane besides your own boat breaking loose is other boats breaking loose, and hitting yours. For a severe blow, your mooring might drag.
Oct 1, 2007
1,865
I've been in Plymouth several times on town moorings and I recall it being pretty open to the E and NE. If it were my boat I'd find out first if they allow you to stay on the mooring in a hurricane (some don't), and how heavy the mooring is and the size of the chain. If those answers are all good, the next thing is the pendant and chafe protection.
Jan 24, 2017
670
Hunter 34 Toms River Nj
If possible attach multiple mooring lines down the rode or directly to the chain at different increments, this way if the main pendant fails you have a backup line attached to something hopefully. Use heavy line or chain and chafe gear. Strap as many fenders or old tires as you can to protect yourself as best as you can from other boats that my breakaway.
I might drop an anchor directly on top of you morning with as much scope as you can. My thoughts here is not to use the anchor to secure you boat but as a fail safe if the boat happens to breakaway from you mooring might give you a 50/50 chance of setting. The rest is in GODs hands.
Feb 6, 1998
11,701
Sadly most US moorings, other than on some of Maine's year round off-shore islands, are woefully inadequate for Nor'Easters or Cat 1, 2 or 3 hurricanes. Cat 4 or 5 all bets are off anyway. Our storm mooring was modeled after Maine's many off shore island year round moorings.
This is our boat on her storm mooring.
We are fortunate enough to have a storm mooring in front of our house in a fairly protected cove with only three or four other boats all spread out.. Our granite block is approx 14" thick, 8' long and 6' wide and weighs approx 9500 pounds. It is long, low and flat and has settled into the bottom so that only the 2" staple is showing. To change the bottom chain, once every 20 years or so, it requires diving as the largest mooring barge in the bay could not get it out of the mud.
For bottom chain we use 30' of USCG/US Navy surplus stud-link bottom chain. Each link is 10" long and it weighs approx 27 pounds per foot. For top chain we use 1" Acco long-link mooring chain & then on to a 1.5" Campbell eye to eye swivel. From there we have two Yale Polydyne 1" pendants, of unequal lengths, which are then connected to two 1" Dyneema storm pendants and one 1" Polydyne storm pendant. For chafe gear I use Chafe Pro... The cleats on our boat are backed by massive 1/2" thick G-10 plates.
Our regular mooring, around the point in Falmouth Foreside, is still pretty robust, especially for our boats size. It is likely more robust than perhaps 98% of the moorings in the US, but you could not pay me to keep our boat on it during a real storm.
This article may be of interest to some:
Mooring Preparation & Precaution For Storms (LINK)
Happily we've not had to put our storm mooring to a real test in years and I cross my fingers it stays that way..
