mooring pendants
Jul 30, 2021
17
oday oday28 chelsea yatch club
what size pendants do I need for an oday 28? boat stays on a mooring field on the Hudson river ( tidal river with strong currents). guy at west marine store couldn't figure out size of lines or lengths. thank you
Jun 14, 2010
2,412
Speak with the contractor who puts in and maintains the moorings in your area. He’ll probably sell you what you need and take care of you as a customer. Might not be the cheapest but it’s always good policy to have the mooring guy as your friend. :thumbup:
To answer your question directly, I’d suggest 5/8” dual pendants 7-12ft long with spliced-eyes and chafe guards. Add a fiberglass pick-up stick on a 3/8" 4' line to one of the spliced loops. Put floats on the pendants every 2 feet so they don‘t sink and wrap on the chain beneath the mooring float. Those currents will cause your boat to do crazy things, especially when the wind opposes current.
ps- you can buy split foam pipe insulation from HD or Lowe’s and use that with zip ties to float the lines. Much cheaper than “marine” floats.
edit: I recommend name brand shackles from Crosby or Acco. Not that Chinese-made no-name stuff they sell at WM.
Welcome to the SBO site.
It is tough to make these decisions. Money. Will it be a calm water experience or should I plan for the next hurricane like the one that came ashore at Sandy Hook.
@Maine Sail has been a member here for many years providing down to earth science based solutions to sailors. He has an excellent website with many helpful ideas for the new boater. One of them is about mooring pendants.
And if you find the info helpful and can share a few bucks it will help him keep the information available for future sailors. His story is on the website home page.
Jun 14, 2010
2,412
You may find that your bow cleat is too small for the recommended pendant.
:thumbup: If that's the case, I'd suggest he add an intermediary dyneema loop that's at least as strong as the pendant. If the loop goes through any chocks or over the deck edge, it should also have added chafe protection where it might rub. Dyneema is more chafe resistant than polyester or nylon anyway, and because it has near-zero stretch it will also move less than the pendent over the same surfaces (less sawing action making it even less likely to chafe).
Edit - New England Ropes makes one called " Cyclone Mooring Pendants" smallest diameter is 1/2"
higgs
Aug 24, 2005
3,715
Nassau 34 Olcott, NY
Kept my 25 footer on a mooring in a field where waves occassionly reached six feet. I use two 5/8" lines with good chafe protection and survived storms others did not. Your big problem may be a cleat that will accept a larger line. Do not, under any circumstances, just toss a loop over your cleat and forget about it.
Jul 30, 2021
17
we have strong currents and sometimes around fall waterchestnuts wrap themselves around mooring ball. recommended size is 5/8 but was wondering if I should go 3/4. 2 years ago we made our own at our club and last year one broke off.
Jul 30, 2021
17
just want something durable i changed mooring ball set up. pendants used to attached to chains under ball now a got a new ball where it attaches on top.
Does the new ball does have a steel shaft that connects the pendant to the anchor chain?
Mooring pendants have a life span, it is short. Chafe is the enemy. Protect the pendant from chafe and UV exposure and it will last longer.
Oct 3, 2011
833
I equate the lines to insurance and the value of what your boat is worth-would you use clothes line?
Everybody hates to spend money but you will sleep better when you have good lines!
ShawnL
Jul 29, 2020
189
Catalina 22 3603 Calumet Mi
I had 3 1/2" 3-strand nylon pendants (on my Catalina 22). 2 to the bow cleats and one longer one as a safety to the bow eye. They tangle some as the boat moves, but I like the setup. Unfortunately we were out of town for a week when we should have hauled her out. There were high winds while we were gone. When we went to haul her out, we found that the line between the float and the sea anchor had somehow wrapped around the keel. Almost had to go diving in Lake Superior in October. Eventually we managed to get everything free, but noticed later that 2 of the 3 mooring pendants were pretty much garbage after all the chafe and stress, Moral of the story -- check on her often.
There is no better form of security than to inspect the systems you put in place for the boat’s safety. Surprisingly this methodology works for many things in life.
Jun 14, 2010
2,412
“Moral of the story” was only part of the answer. The solution that would likely have prevented this is to put floats on your mooring pendants at least every 2 feet to prevent sinking and chain wrap. The next thing is that your mooring buoy should float deep enough for the pendants to ride over (not under) the buoy if there is a pull reversal after a slack period. It’s better to undersize than to oversize the buoy. It’s all part of a system.
