Shortening the pendant
Buck, I wouldn't shorten the pendant line on your mooring ball. Your boat will lift the mooring block and you'll lose your boat on the very next storm. Moorings will generally bury themselves into the mud and that's what really holds them, whether it be a concrete block or a large mushroom anchor. Think of your mooring as an anchor. As long as there is a horizontal pull on the chains and line, your mooring should hold. The bottom chain is probably 1-1/8" large Navy chain, and your top chain is probably 1/2" with a large swivel between them, and that weight helps to keep your ground tackle at more of a horizontal angle. Shortening the pendant line will give you a more vertical pull, and the mooring is sure to drag. I would seriously rethink this one, Buck. I'd hate to have you lose your boat. There has to be a better solution. I'm surprised that your harbor master told you that this may work. Sometimes the wind is stronger than the current or visa versa, and this can cause a boat to ride up on the ball. It happens in our mooring field on the river. Maybe some "No Wake" signs would solve this issue, or maybe a different mooring location on the river. I've heard our guys complain about the boot stripe on their boats getting ruined because of this, but no one is having a problem with their pendant line getting wrapped around the chain if they are using some kind of pendant line flotation. I wish you luck!Joe
