Jeff
I recently purchased a Beneteau 423 and will be keeping it on a Mooring ball. I am not overly pleased with the harness set up I am using. My current harness is made of two lines - each 7/8 inch diameter three strand nylon - 12 feet long that attached to a shackle on the mooring ball. Anyone from Chicago who has been at Monroe Harbor will have a clear understanding of this set up.With this arrangement I am getting chafe on the eye splices that attach to the front cleats when moored. I believe the chafe is coming from the eye splice rubbing on the middle screw head that is used to hold the stainless protection plate on the teak toe rail, that is just under the cleat. The second issue I have with this arrangement is as the boat swings the lines seem to rub the gel coat at the tip of the bow below the bow roller. This winter I saw another 423 that had this harness arrangement that was a blue hull and the blue gel coat was in need of repair after their first season.Any suggestions for minimizing chafe and keeping a secure attachment to a mooring ball? Anyone out there have a set up where the mooring lines, or short chain, run through the bow roller?
