Mold Behind the Bookrack
A
Andy Sokolowsky
My 1990 C 28 has a bookrack or holder attached to the built in cooler on the port side of the cabin. the cooler was retrofitted with a refrigerator which work great. the problem now is the relatively cooler outer surface of the cooler causes condensation behind the wood bookrack which then provides a perfect combination for growing mold despite the placement of small spacers between the rack and the cooler. any other ideas?
L
Lauraine
Sounds like you could use some more insulation
Can yuo get a piece of styrofoam insulation inside the cooler on that wall? Or maybe some spray foam?
L
LaDonna Bubak - CatalinaOwners.com
Silver bubble insulation
I'm intrigued by this stuff called Reflectix. Use a chunk in the icebox as a thermal blanket, tuck some behind the books to protect from condensation, etc. You might try something like that... LaDonna
