Reading a moisture meter
... is far more art than science. The user of a moisture meter should have a lot of experience using the same device on a number of different boats, and surfaces (wood, solid fiberglass, fiberglass with balsa coring, etc.). I personally think that a $5 phenolic hammer is just as good at telling you the condition of a surface as a $400 moisture meter. The key to me is how practiced the user of either tool is. In your case, I would discuss this issue with your surveyor and get a sense of his experience with his tools. Years ago, I had a boat surveyed that had one of those cockpit lazarette hatches that was very shallow (as a quarter berth ran under it). All you could fit in the locker was a few lines or a horn. The surveyor ran his moisture meter over the hatch cover and declared it 100% wet or compromised. You know how this story ends....I picked up the hatch cover and locker had about 2 inches of rain water in it....which the moisture meter was reading. I bought the boat, but never used that surveyor again.
