Has anyone modified the vertical teak panel that separates the starboard lazarette and the port quarter birth? I was to replace the fuel/water separating filter this afternoon, and got in lazarette and almost didn't get out! Working in confined space is tough if you have hip/back problems...
So I thought 'why not cut a hole (or a couple of 'hatches') in the vertical teak panel that separates the lazarette and qtr birth? Does not appear to be structural as I can see daylight at top edge... Could recover at least 3' of unused space - may even move batteries further aft and help with rainwater retention in cockpit after a rain.
Anyone done this before, or have any comments to this plan? Oh, Groco filter (that I didn't think had a filter) DOES have a filter. 'Cardboard' top looked like grainy inside of filter body, so thought it had been removed. Thought I was seeing bottom of filter casing since I had no 'convenient' fuel shut off valve and didn't realize the filter sat down in the body 3" or so... Probably could have saved myself a lot of work, expense by just replacing filter. But glad I have the Raycor with clear bottom so I can now see if water/trash is coming out of tank...
Charles
Charles
