modifying refrigeration system on 410
Feb 26, 2010
16
Hunter 34 Punta Gorda
Has anyone separated the freezer/refrigeration system by adding an additional refrigeration unit and blocking off the spill-over fan system.
I anyone has I would be interested in how the piping was routed and problems experienced and resolved
Thanks in advance
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
Did it. Blocked off the holes. Just left the old t'stat and keep it off. Put new air cooled unit behind the oven and just ran the ref piping in the side of the box. Installed a small unit with one flat plate. Ran new wiring under the floor to a breaker on the panel. It works great.
Feb 26, 2010
16
Thanks in advance
Sailgunner, appreciate the input, but Has anybody install the new refrigeration unit under the Stb Settee and put the tubing through or behind the freezer compartment. In my freezer there is an L shaped blocked off area in the left rear corner, does anybody know what is concealed within that blocked off area
Thanks
snows
Aug 22, 2011
30
Hunter 410 Charleston, SC
Thanks
There is a hull stringer behind that L-shaped area. You can see it by removing the LP Gas solenoid panel and poking an iPhone through the opening with the flashlight feature turned on. I've seen a lot of the boat that I otherwise wouldn't have been able to see by using my iPhone.
Good Luck.
Daniel
Feb 26, 2010
16
Good Luck.
Daniel
thanks Daniel, you are right
