Joe,
Thanks, how to set the riser hights is my current mental project. I understand you used a jack to raise them but when did you do this? While you had it on the ramp? Are the bunks 2 X 6 pressure treated? Thanks!
Jeff,
I did it at our club one day when I first brought my new trailer down there to load my boat on it. We have a pretty good ramp. What I did before I loaded my boat on the trailer was, I got a rough measurement of the height of the rollers on my old Load-Rite trailer and set my bunks up for that height. As it turned out though, the bottom of my keel was sitting about an inch or two off the keel board after I loaded her on the trailer and pulled her up on to level ground, but that's OK. In other words, the bunks were supporting that boat plus the keel. It's better to have your bunks set a little high at first than to have them set so low that when you pull the boat out of the water, the boat tips to one side.
Then I pulled the trailer over to the level ground. I don't remember whether I lowered the boat down so that the keel was sitting on the trailer's keel board, or whether I chalked the trailer wheels and disconnected the trailer from my truck and checked the tongue weight. I remember backing the trailer down the ramp and letting the boat float back a few inches because the tongue weight was too heavy. Wayne was there that day and he said, "I'd let the boat float back about to this mark." We used one of my trailer's guide posts as a reference and I lightly drew a pencil mark where he pointed to on the hull. After I pulled the trailer back on to the lawn again and got the proper tongue weight, I left the trailer connected to my truck and proceeded to lower my boat so that the keel was setting on the board. I may have used two of my sailboat stands, one on each side in the stern of my boat to hold the weight and keep the boat straight as I lowered the hull, plus my hydraulic jack under the bow from the ground, or sitting on planks on the trailer frame. There are so many ways to do this. I probably lowered the two sailboat stands a little at a time in conjunction with the hydraulic jack after I loosened the bunk extension brackets. After I got the weight of the boat plus the keel sitting on the keel board, I put a jack under each of the center extension brackets and raised them up to the hull. I took measurements and tightened the bolts and did the other extension brackets in the same way.
I used two 2"X 10"X 8' pressure treated planks for my trailer's keel board and I cut about 10.5" off them because they were a little too long. I counter sunk the holes for the carriage bolt heads on the top plank with a large Forstner bit and used a 3/8" drill bit for the carriage bolts.
If I didn't have my sailboat stands with me that day to lower my boat on the trailer, I'm almost certain that I could have done it with three jacks. If you look carefully at my trailer, you'll see that my winch stand is on the inside of my trailer frame. That's where it needed to go after I got the proper tongue weight. I've been very fortunate that my trailer is long enough for me to back down the ramp and float my boat off it without swamping my truck, otherwise I'd have to install an extension tongue on my trailer like Wayne has on his.
Joe
