Modified Traveler 23’ Hunter
Jun 13, 2022
2
Hunter Hunter 23 WK ocean City New Jersey
Just completed a nifty modification to my traveler that allows me to micro or macro adjust the traveler while on the tiller. $100 worth of blocks and 5/8th line.
Congrats. Should help you smoothly trim the Main sail.
-na -NA Anywhere USA
Did you drilled and tapped into embedded aluminum plates in the fiberglass? If not, how did you secure the stainless steel bolts inside as you would have gone through the deck and an interior head liner?
Apr 27, 2010
1,279
Hunter 23 Lake Wallenpaupack
I did something similar, love it. On mine, the track was already secured with bolts and nuts through to the interior. I had to unbolt them all, remove the track, place the fittings on the track ends and reinstall track using boat life caulk.
