I bought silicone bronze hardware from Fastenal, I had to order them though.
I second the fiberglass backing plates. If I can impart one word of advise, buy GOOD hole saws to make them. I had some cheap ones from harbor freight, and it was dull before it got though the first plate. Also I would use a drill press if you have one, and have someone pour water over it while you cut it. The fiberglass dust filled up my whole shop and was nasty.
To make the fiberglass backing plates, I layed out wax paper on an old table, taped it down and used a small roller to start laying down polyester resin. I used 10 oz. and 24 oz. to make the 1/2" thickness, but I think any woven will do fine.
I power sanded the hull inside and dewaxed everything. I used thickened polyester to adhere it to the hull. Explore that link I posted before.
