this has worked for me.....[ long msg. ]
small mixing cups are great but if its just a small quick batch you can use a small piece of clean cardboard and a tounge depressor,[blunt one end with a razor blade first.] if you have an amount of gelcoat the size of a reeses peanut butter cup,[ sorry i could'nt quickley think of a better example] add no more than 4 drops of m e k catalyst. small batches are not rocket science. always add the catalyst 1st then mix into the gelcoat colloidal silica, west system#406 is one example and there are other brands ,mix it into the consistancy of mayo not p-butter as there will be some shrink as it cures and if its to thick it will crack,use a well placed heat lamp or just wait several hours, DON'T BE IN A HURRY! a bastard cut file will make quick work of roughly shaping the repair,block sand it flat,wet sand,polish.....your done!
