Mixing battery chemistry
Sep 22, 2014
9
Hunter 33 Parry Sound
It appears that you have a split house bank, and use the switch to put them together. Why bother?
Wire them together for the largest house bank and use that same switch to control your reserve bank.
Yes Stu, as far as I can tell the house bank is 2 batts in parallel each side of the 3-pos switch below the fuse panel. The boat came to me (2nd owner) that way and I assume it was as built. Since the reserve (single engine start batt) has its own switch next to the batt in the cockpit locker, I am inclined to leave it that way.
Dec 29, 2008
806
Treworgy 65' LOA Custom Steel Pilothouse Staysail Ketch St. Croix, Virgin Islands
There may be some, but I know of no battery chargers that will charge batteries of a different chemistries.
Just an FYI, both our Xantrax charges can be programmed so each output to a battery can be set to that specific battery chemistry, FLA, AGM or GEL. Can't recall if there was another option. I would have thought most newer chargers would allow that, but I haven't shopped for a charger in the past 7 or 8 years.
