Try rubbing a small amount of fuel between thumb and forefinger and see if you can detect a faint oily consistency when compared to straight gas. You might also set two samples, one of known straight gas and see which one evaporates quicker. The oil residue should take a little longer. Both these methods require educated observations and might not be of help but are the simplest ones I know.
