Miter cut
Miter cut is an old fashioned method of preventing extreme 'bias stretch' of old technology sail material. Modern (higher end) woven materials by their engineering and fiber/weave alignment do not have this 'problem' to the same degree. I perceive miter cut sails allow the sailmaker to use a cheaper, less stable sail material. If you actually know how to adjust the shape of your sails (halyard, cunningham tension, etc.) a miter cut wont respond to this reshaping as a standard cross-cut .... ie.: heavier halyard tension wont result in much location of max. draft in the bottom sections of the sail where draft location is normally difficult to control in most sails. With a miter cut sail the more sheet or outhaul tension you apply the max. draft will tend to move lower in the sail toward the foot the more sheet or outhaul tension you apply especially if the sail fabric is 'stretchy' -- good for 'storm' sails but not for general 'cruising', etc. A radial, etc. cut will tend to stay in the shape that the sail is originally cut .... with the major axis of strain in the fabric aligned with the major axis of strain of the windloading, etc. and are relatively non-adjustable w/r 'shape'. If you are a 'cruiser' and simply 'raise' but never shape your sails ... all this doesnt make any difference as most of the time you will have 'deplorable' sail shape anyway ... especially if you dont have a local sail loft come to your boat, go sailing with you to see how the boat and rigging performs, determines how good or how bad a sailor you are, do the 'actual' measurements on the boat, etc.. If you are not knowledgeable nor even 'care' about 'sail shaping' then the radial cut will be the longest lasting while holding its overall shape and give the very best performance. IMHO if you're not actively racing, the cross-cut remains the best value and has the highest ability to be 'reshaped' (max. draft position, etc.) but needs some measure of 'quality' material to remain shape stable over time. The miter cut falls somewhere in between the two (but is unnecessary if you use 'good' materials).
