Missing pages in the manual. c&c 29 mk2
Jul 24, 2025
3
C&C 29 mkII North East
Hello,
I have the original owner's manual for my C&C 29 Mk2 boat, but unfortunately the three pages I find most interesting are missing. These are figures 16, 16a and table 6. If anyone has such a manual, could you please share photos/scans of these pages?
Thanks
This maybe one of the pages.
if considering new sails, would suggest you consult with a local sail loft to examine your current plan and identify new sail options.
Your engine manual would be better searching for it on the engine in your boat. The boat builder sourced the engine from an outside manufacturer. This is the case for many of the systems found on a sailboat.
Likes: Stu Jackson
Jul 24, 2025
3
Thanks for suggestions.
One of the goals is to restore the original manual to be completed.
And another - to choose the right prop. When I bought the boat, there was a 12x9, but completely rotted. I put in 13x6 and it works acceptably, but I would like to know the original size.
When I dealt with the prop replacement, I did what the manufacturer did when planning the boat build.
I took the engine data, the transmission data and the distance from my prop shaft to the hull bottom to a prop maker. (In your case case include the distance from the end of your shaft to the strut if you have one).
With this information the prop maker knew exactly what prop was needed. It was manufactured and installed as expected. The results have been terrific.
