Shaft Mis-alignment
Pete,When I purchasesd my 79', it needed a cutless bearing. Went to pull shaft: dropped rudder, but coupling would not release. Placed 2 X 4 across hatchway and used boom vang as hoist to lift engine out of way, removing shaft to bow, and to do work. It turned out to be fairly quick and straight forward. You only have mount bolts, fuel, 2 control lines and few electrical connections, coupling was all ready released.Anyway, the point here is that after purchasing a new shaft and installing new cutless, much to my surprise as I inserted the new shaft through the cutless to the shaft log, expecting it to hit at least close to the hole, it was almost 3/4 of the shaft diameter off.The final fix was to reset the strut. I removed the strut, opened up all the mounting holes to allow for adjustment, then dry fit everything, with moter reset in compartment. Actually had to put a slight twist in the strut to make things work.Finally, used 5200 to bed the strut and allowed set to occur with shaft in-place with multi-step tightening of the strut hardware, always checking rotational friction after each tightening.That was two years ago and she's still running smooth as silk (so to speak). I was not surprised that it needed a cutless when the original factory fit was so poor.Good Luck!
