I have an inflatable dinghy (Mercury 240RU) that has a really small nick in the flooring. It has not penetrated the material but it has become translucent. It is probably 1/4" or less in length and very narrow.
According to the manual, I should use a patch to repair. But this is not a tear, just a nick. I think if the nick open then water will start to come in and could eventually open up more.
So with that, do you guys have any recommendations for rubber cement that could be used to just fill in the void of the nick? Something I can apply to both sides of the flooring as a filler?
If there is a possibility of this nick expanding then I will use one of the patches in the repair kit I have. But until then, a little preventative maintenance as a start is in order.
As always, the expertise on this board saves the day. And thanks in advance.
