Years ago I had to replace the Fuel filter on my Yanmar 2GM20F Engine because when I went to bleed the fuel line the fuel filter threads came out along with the screw. I replaced the fuel filter, replaced all the fuel lines and all was well, or so I thought. After some time I noticed a fuel leek on the input hose to the fuel filter, I tighten the hose clamp, but the leak was still there. I then replace the flexible fuel hose, but it still leaked. I put on two hose clamps, and it still leaked. During this long period of time I kept those oil absorbing pads under the filter.
So once again this year I once again decided to investigate the problem. While working on it I noticed that the hose went onto the barb very easily, I had a AH HA moment, I will replace the 5/16 in hose with 1/4 in hose. That did not work as the hose would not fit. Then notice that on the hose barb there ring indentation around the barb as if it was missing an o-ring. I bought some o-rings at the hardware store but they would not stay in place when the hose was pushed on.
I am now looking to the great hive mind of experts here to see if you have a solution to my problem. Attached are 2 pictures, the first is of the fuel filter / barb with the hose pulled off, the second is from he Yanmar manual. The manual says that there should be a rigid pipe between the fuel feed pump and the Fuel Filter and I cannot find the the type of hose barb that I have on the engine. What I have came this way from Hunter as I bought the boat new.
I want to thank everyone for you help in advance.
Ken Pfaff
S/V Wanderlust
Ken Pfaff
S/V Wanderlust
