Minn Kota 50
Dec 29, 2021
89
Catalina, Tanzer C 22, 16 10910 Starr SC
I'm having to work on my Mercury 7.5 and waiting for parts. In the meanwhile, I have a 50lb thrust Minn Kota that I just bought for my Tanzer 16. Anyone think the MK will work to get me out of the slip and into the channel?
AaronD
Aug 10, 2014
751
Catalina 22 9874 Newberg, OR / Olympia, WA
I tried our 55lb Minn Kota on our C-22 a couple times. It worked to move along in calm water. It couldn't fight a current at all, and was pretty difficult to hold steady into a breeze. I'm pretty sure the battery I had at the time wasn't enough to maximize the electric OB's thrust; our current battery bank and thick cables might do a little better. But I still wouldn't expect a lot.
Yes, it should get you in and out of the slip in calm water and mellow winds. It would probably be optimistic to hope for much more than that.
Dec 29, 2021
89
I came across a MK Riptide 80lp thrust but it's 24 volt What to do.
Sep 24, 2018
3,998
Catalina 30 MKIII Chicago
I've used a 36lbs motor on a 19' boat on a few calm days on lake michigan. There was also a fellow at my marina that would take his Chrysler 22 out with a 24v trolling motor. I'm not sure how much thrust his motor had but it worked for a season before he got a 9.9
Dec 29, 2021
89
I took my Tanzer 16 out with the MK 55 and only needed the 3rd gear (out of 5) to move the little boat at a comfortable speed (perfect for trolling for fishing). It should do OK to get me out of the slip and back in.
