Mike Thomas - need your advice
Don
Just bought a 93 Hunter 37.5 with the A/B Super Cold machine installed. The water pump feature, however, has not beed not added. I sail on the Chesapeake and think the water feature will be benefical in the summer heat. (1) Do you agree? (2) Assuming you do, I'm planning to install a thru-hull so that I can add the water feature shortly. What size should I use? 3/4", 1", somthing different? (3) Also, how do I order the water feature? Through you or one of the retailers? Thanks. Don
BILL THOMAS
Don
I hope my email answered your questions. If not, let me know.
Don
Yes Bill,
Thanks a lot for the timely response. You guys are great. If you don't remember me, I was the one in Annapolis last July with the new Frostmate that wouldn't run. You all were terriffic about finding new parts, telephone calls, etc. Turned out, that the problem was a loose connection on a wire at the control module. I replaced it and all ran well. I traded boats this winter so I'm back. While my problem last year points to a small manufacturing error, your customer service saved the day.
