older hunter/ 4 cylinder yanmar powered question.
many would tell me to go to cruisers or engine forums for the answer to this,(as many answers as there are questions) however I am going to ask it here.
I have a 4JHE "(non turbo 4 cylinder) yanmar in my 85 H40, I have cruised by others boats with yanmars, tho few of this vintage....total hours is in the 5K plus range I am guessing, tho the meter only shows 2K(perhaps previous servicing folks installed the meter later) anyway.
like most yanmars the only time I dont notice a fair amount of smoke is under full power. 40 hp at 3500 rpm. lower speeds result in noticeable smoke, starts blue turns grey-after warming upbl. slight sheen on the water surface when idling, Fuel is sweet, little bit of black soot that has to be cleaned off the transom every trip. doesnt consume lube oil. (1/2 quart after 80 hours). I can run it from a clean gallon container of fuel and no change in smoke properties. (not quite an m1Abrams in defensive smoke generation mode but far more than seem necessary for a 1980's engine..... I guess
I know about the leak down into the cylinders after shutdown, and having all that extra carbon to remove when the engine gets hot again, I am aware that these engines have mechanical fuel metering, (I ha ve spent the requisite hours dissassembling with the good yanmar manual) they are finicky. to get enough fuel at full load makes them run a little rich at lower 2200 rpm or so, the little beast is reliable. seems to start every time, shakes like a little monster at 900 rpm, can get to 3500 rpm with the current prop, and the boat does a little over 7-1/2 kts. fuel Inj timing checks out per mechanical markings,
Compression on this engine is still strong,
is just me?.....or does this thing just smoke more than a perkins, atomic, bmw, or any other diesel that I have ever played with.
does everyone elses smoke too much at low to medium rpm's?
