I have a 1987 Morgan 41 Classic and been having problems with a prop mid shaft bearing. It looks like the previous owner had replaced the bearing with something that is not to be used. Does anyone know what the original bearing was? I called down to Largo and they told me it was an RCJ 1 1/4 Flange mounted bearing. I can see how that would be the case but... The stringer that the bearing is bolted to is about 10 degrees out of alignment with the proper shaft. That would mean the bearing would need to rotate 10 degrees off center! I have not found an RCJ 1 1/4 bearing that could do that. Any help out there?
