Mid season engine oil change?
James Dugan
After the July 4th weekend, I generally change my Hunter 336 (3GM30F) oil and filter as I do again in November the day I put her on the hard. My total engine running hours so far this season is about 200 and I usually only add another 150 for a total of 300-350 for the season tops. I really do not have a problem doing this small task but am I being a bit too much of a motor head by changing the oil/filter twice a season with low operating hours on the engine. Please advise.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
My sense of this is that you can't be too rich, too thin, or change your oil/filter too often.... I think your oil change schedule will lengthen the life of your engine, at little cost or effort to you. FWIW, I change my oil/filter at about 100 hrs of engine use or each season, whichever comes first.
timvg
May 10, 2004
276
Hunter 40.5 Long Beach, CA
My Yanmar manual says every 150 hours. I usually do it every 100 hours, but not more than 150. I also change my fuel filters that often, even though the manual says 300 hours.
