K
Ken Palmer
I tried sending you a response, and my e-mail bounced. Now the whole world will see the answer. In reference to changing the rudder stuffing if the boat is in the water:I guess in order to answer your question accurately; I would have to see if the top of the rudder is in or out of the water when at dock-side. I think you can see where I'm going with that.I changed mine out of the water, and Liberty was launched yesterday. Last night I checked on the rudder stuffing box, and saw that it was dripping about 1 drop a second or so. I tightened the nut another half turn or so, and I think the dripping stopped. I need to confirm the tightness by the weekend I think.If water can come up the tube that the rudder shaft is inserted into, then you would have to do something to stem the flow of water once you get the nut all the way off the threading. You might be able to do that with tape and/or rags. Getting the old stuffing out and the new flax in was a time consuming process. I am glad that I didn't have the water to worry about. If you have your boat pulled in the winter, then I would wait until then as long as the leak you must have now isn't too bad.Have you tried just tightening the nut with it's present stuffing? You might be surprised what a little turn will do.I hope that answers your question.... and more. Thanks for writing.Ken Palmer, S/V Liberty
