I am well aware that Merriman Yacht specialties has been out of business for years. The fuel control lever on my H-34 has become loose. Taking upper pedestal unit apart apart yesterday revealed a broken aluminum casing on the inside part where the shaft of the lever is supported.
Has anyone had this problem ? I am thinking of having a welder rebuild the area, then I could bore a new hole for the shaft support. Or perhaps insert an aluminum block and rebuild the lever support that way.
Ideas and suggestions welcomed. Thanks for the help.
