Our heat works fine for about two minutes and then the unit itself trips off. The water flow is fine. Excellent heat comes out when it briefly works. Any ideas why it trips off? It works continuously and does not trip off when in cooling mode.
Ok, so after reading a little on the manufacturers website I found the problem. They said it could be caused by an air restriction. So, low and behold when I checked the two cabin air vents, guests had fully closed both of them! I opened the vents and the heat works fine...
