On the transom of my MAC 25 there merc 7.5 . The tell tale shows it is cooling properly until reved up and becomes intermittent. I tried the flush but it didn't seem to help. Any help on the impeller and the tube that runs up through the shaft, gaining access to it for inspection and repair, and a source for these parts? Also, is the water intake the small aluminum looking vent on the lower end of the motor?In the spartan manual it shows how to replace the lube in the lower end but the photo is so poor that I cant seem to locate the "vent hole" so I can change the gear lube (any suggestions on what to use?)Are the 2 black caps on the shaft covering some bolts that I need to remove for access to inspect the coolant tube? How do you remove the caps w/o damaging them, probably just prying them off, but when going into uncharted teritory it is good to be armed with some direction and experience...Geez, lots of ?'s...Thanks in advance
