measurement help!
74
Hunter 356 Nashville,Tn
I am moving my 2003 356 to Maryland soon and I am looking for some help with measurements so I can get some transport cost quotes.I know the obvious ones like beam but I was hoping someone might have moved their 356 and therefore know:1.What is the length of the mast,it is 55 feet in the specs but I assume that is from the waterline. 2.What is the heighth from the bottom of the keel to the highest point on the boat(with the arch removed)? Thanks
MKing
Been There
Paul, I had the same questions this Spring moving a 306 from MD to TN. emailed Hunter and they promptly returned all the specs. They were all in Metric for export purpose but easy to convert. Hunter ships with the arch removed so the numbers they provide will be what you need for the quote request.(rest up and take friends when you remove and reinstall the arch...it's quite heavy)
Jun 4, 2004
74
MKing!!!
What did your cost end up being and who did you use for the trucking company?Were you happy with their service?Any additional info would be helpful.Thanks
Popeye
Boat Transport
Paul, I used Cross Country Boat Transport out of Hastings MN. They shipped my 40.5 from Daltiville, Va to Bayfield WI in 2004,cost 4,750. I have personally talked to 3 others that used them. Excellent company no complaints. 651-437-2454
