Measure from boom to cabintop (for vang)
Tom Wootton
I'm planning to order a Garhauer rigid boom vang for my H26. As per their instructions, I traced a profile of the mast and boom sections using solder wire, so they can customize the mounting brackets. But I forgot to measure the distance from the underside of the boom to the point where the mast bracket can be mounted. (I know, I know...CHECKLIST!) The boat's over an hour away, and I won't be back til next weekend. It's a '95 with a Z-spar mast (not sure if that matters or not). If someone can give me the clear vertical distance between the boom bottom and the cabintop (measured at the mast) I can adjust it for the bracket location (I DID remember to take closeup pics of the mast base). Thanks in advance, Tom
Michael Bell
Sorry Dude
Mine is an hour away also - or I would I have them for you.
Tom Wootton
Never Mind
Garhauer was able to select the proper vang and length (RV16-1) from the templates I faxed them and their prior knowledge of the boat. They had already started on the brackets when I called today. I'll post a report after I install it.
