Hi,
I have just installed a tachometer (Tiny-Tach),
sailed a short test,
and finally I know how fast my MD6A and Combi rotate!
To my surprise, it turns out that I never run it faster than about 2300
rpm. On flat water, the boat makes about 5.7 knots at 2250 rpm.
I actually feel much more comfortable running it 200 rpm lower,
at about 2050 rpm, which gives about 4.9 - 5.0 knots.
I think this is my usual engine cruising speed.
Do you think it is normal ?
I seem to remember that MD6A was designed to operate at ~2800 rpm.
I wonder if I should change the revs - Combi propeller pitch
synchronisation. I mean reducing the pitch
at a given throttle setting, i.e. reducing the engine load
(by turning the yellow cam at the combi).Another question:
since ever, at about 1600 rpm (now I know it is 1600 rpm
I get strange vibrations. Seems that this is the alternator
which periodically vibrates (a series of noisy, visible vibration
once per 2 seconds, or so).
What could be the reason of such vibrations and how
can I get rid of it ?Cheers,
Marcin
V1958 "Lotta"
Marcin
V1958 "Lotta"
