MD6A: One or two V-belts from starter motor to flywheel?
Oct 19, 2019
921
Albin Vega 27 Limerick
Hi all.
Two questions:
First: There is provision for 2 V-belts from starter motor to flywheel -
as there are 2 corresponding "V"'s on the flywheel and on the starter
motor wheel.
I only use one - should I use both?
Second: I find it difficult to tension my (single) V-belt from starter
motor to flywheel.
Obviously the bolt on the tensioner arm and the bolts on the body of the
starter motor need to be loosened.
Then I use a piece of wood to push the starter motor away from the
flywheel then tighten bolts.
Trouble is I only have 2 hands and one I take the load off the piece of
wood the starter slips before I have time to tighten the bolts.
Any tips?
Thanks,
John
John A. Kinsella Ph: +353-61-202148 (Direct)
+353-61-333644 x 2148 (Switch)
Mathematics Dept. e-mail: John.Kinsella@...
University of Limerick FAX: +353-61-334927
IRELAND Web: John Kinsella's Website
May 30, 2006
1,075
I think you are supposed to attach both belts.brbr
Another thing to consider... If you still have the old dynastarter, the bearings may be getting old and it may run a bit hot (once you get it running you can feel it.). Anyway, I have my belts as loose as possible so that I don't put undo pressure on the bearings until I can get the unit to a shop.brbr
roy
