Hi group.
I am in the process of removing my MD6A engine and need some advice.
Will the exaust pipe tha is in the after end of heat exchanger
seperate whe engine mounting bolts are removed?
I cut the large rubber hose that the pipe goes through and will need
to replace it.
I can't get at the 4 bolts in the rear of heat exchanger taht hole
the flange where the rubber hose connects to.
Does any one know where I can fine the large rubber hose to repalce
the one I cut.
Thanks for any help you may give.
Best regards to all,
Giani
SV/Puffin 1554
to replace it.
the one I cut.
Giani
SV/Puffin 1554
