Hey gang, sadly, I have been informed that I have insufficient compression and need to rebuild my MD6. It has the combi. which I want to remove/renovate at the same time. Questions:
(a) Is it possible to remove just the prop and pull the entire engine, combi and shaft forward into the salon and hoist it up and out the companionway hatch in one piece?
(b) If not, is it possible to simply unbolt the combi at the block and slide the engine forward and off the spline, leaving the combi behind without dismantling the whole combi?
(c) If I do as suggested in (b) am I going to then run into problems breaking apart the combi to remove it?
I am going up tomorrow to start the job, so any speedy advice would be greatly appreciated.
Thank you very much. Trevor (V2915)
_________________________________________________________________
[Non-text portions of this message have been removed]
