MD6 bites back....
Oct 30, 2019
114
Hi all, I thought I would check the impeller today. I have a load of spare impellers (came with the boat) and it was just a bit of light relief really - I had fitted the other storm window, put a bit of sealant along the hull to deck joint, fitted the replacement prop boss plug, fitted the nylon rollers on the new anchor roller and I just thought it would be wise to see how easy it is to do. Well... joy of joys it is easy to get at and the little bronze cover is attached with knurled knobs... just twisted them and off they came.. all went well and I levered out the old impeller with a couple of screwdrivers and I was quite pleased with myself. One thing did surprise me - the instructions said to undo the little screw but it just came all the way out with screw in situ. Not to worry, I put a cable tie around the new impeller and tried to slot it in - no joy! I thought I was not aligned with the slot (mine has a slot - not a hole for the screw)but no matter what I tried it would not go in! Anyway I took it out and compared it to the old one - they were not the same - the internal diameter on the old one is about 12mm and the new one is less - maybe 10mm. Whatever next - I checked the part number and the new one was correct for an MD6! I can only assume that someone has changed the water pump at some stage and all my spare impellers (4 of them) are no use to me! I just put the old one back in and I have ordered the correct size replacements. Lesson learnt - check everything!!!
Oct 19, 2019
921
Albin Vega 27 Limerick
Yes - the Sea Sure is well worth the money.
The original water pump cover with the tiny ?4mm length ?1mm diameter screws was a nightmare.
Anyone who successfully changed the impellor with the old cover while at sea, at night and under time pressure deserves a medal.
Even tied up alongside it was incredibly fiddly. The slots in the heads of the tiny screws were easily damaged making the screws v hard to turn.
The best value for money of any upgrade I installed on the boat.
John V1447 Breakaway
John Kinsella
Mathematics and Statistics Dept
University of Limerick
Phone 0035361202148
Web jkcray.maths.ul.ie
