Hi all.
I have an MD6A and the water pump impellor is a Jabsco 4528-0001K
6 blade. Width: 3/4", Diameter: 1 9/16". Shaft diameter: 3/8". Drive: Slotted shaft pin.Fortunately I replaced the original water pump cover last season - with
gasket & (?) 5 tiny bronze screws - by a custom cover with O-ring and 4
knurled screws; easily turned by hand.
But securing the new impellor with the "slotted shaft pin" is still a pain.
The impellor must be seated on the Water Pump drive shaft which has a
(?) 3-4mm hole drilled through which takes a threaded pin with tiny
Allen key head to secure the impellor to the drive shaft.
This was a PITA to screw into position. I finally managed to rotate the
drive shaft to get a clear line for my equally tiny Allen key.
There "must be a better way" (TM). If I had been 10 mins of the rocks,
the rocks would have had me....
Fortunately I was on my berth...
Any suggestions?
Replace rubber/nylon impellor with bronze casting???
(BTW the old impellor was just starting to develop a crack at the base
of one of the blades so for once I seem to have got there in time..
John V1447 Breakaway
Any suggestions?
