hello all
1st post here.
the last time i ran the engine i noticed excessive wht smoke or steam which isn't normal.
my girl friend had been living aboard for a month in victoria working on her pilots license. i showed up at the boat the day before we were set to leave , checked the dip stick and it showed oil just on the very tip. she does burn a bit. as i've been having starting issues , (old batts? ) i wanted to make sure it was going to fire up. as it takes forever to put oil in and i was only going to fire up and shut down i didn't top up the oil as i would do this the next morning before leaving.
fired it up , started no prob , shut er down , went to movie.
the next morning i checked the dip stick again this time the oil showed all the way full???
kinda perplexed and with a lot of running to do ( 3 days) i added a bit (1 L maybe) to be on the safe side. the whole run up she was spewing wht smoke intermittently , especially when the thermostat would open. i'm wondering if it is too much oil causing this?
i also fueled up on one of the gulf islands where i may have picked up bad fuel.
otherwise this engine runs fine.
any thoughts suggestions?
1st post here.
