J Matos
I reciently lost the starboard stays chain plate on a regatta. From detailed check I discovered that the wooden plank that sits under the plate and the upper hull to which the chain plate attaches had water damage. The plank broke and tha whole piece, including the chain plate got loose, making the mast go down.Has anybody experienced a similar problem?I plan on replacing the plywood plank with solid teak and extending the metal bracket attachment(or tang) farther in the wood plank so that it has more tension distribution.Any other ideas?
