I recently purchased a Hunter 25.5 and the winch needs repair. It is a Maxwell 17 and the springs need to be replaced. Where can I purchase these?Janshag@aol.com
Jan,Call Maxwell. They no longer make sheet winches, but they are still inbusiness and can supply springs for the 17 or 17ST.Before you order the springs, check the clutches. Hold each pair together between your palms and try to rotate them. If they slip they should be checked.I have lost Maxwell's phone, but the fax is 949-631-2846.Dave Weir"Last Resort"
