Dan Anderson
Has anyone rebuilt a Maxprop? My surveyor says the Maxiprop blades on a Legend 45 I'm buying are loose and the hub needs rebuilding. Is there a measurable freeplay in these blades? Will they tighten up with a proper lube job. What gets rebuilt in the hub if the gears are ok? I'm cautious but curious, but it seems to me that you want "loose" blades rather than binding ones. Any thoughts out there?
